disable sflow
disable sflow
Description
Globally disables sFlow statistical packet sampling.
Syntax Description
Default
Disabled.
Usage Guidelines
This command disables sFlow globally on the switch. When you disable sFlow globally, the individual ports are also put into the disabled state. If you later enable the global sFlow state, individual ports return to their previous state.
The following command disables sFlow sampling globally:
disable sflow
This command was first available in ExtremeXOS 11.0.
Platform Availability
